Go Back   Forum Index > Oday Owner Forums > Day Sailers
Day Sailers Odays 26' and under
Reply
Thread Tools Search this Thread
Old 11-06-2009, 02:11 pm   #1  (permalink
desertdan
O'Day Daysailer
Santa Fe
desertdan hasn't generated any comments yet, may be new around here
Hardware help
I'm going to replace the ancient Harken mainsail block on my 1984 O'Day Daysailer but I'm concerned about anchoring the base of my new Garhauser swiveling system on my centerboard trunk. I haven't removed the existing block system yet (we've had recent snow up here so there's no real hurry at this point!!) but I'm concerned about how to anchor the four screws of the new block into fiberglass. There's no way to bolt to a plate underneath. Any suggestions?
desertdan is offline
Old 11-06-2009, 04:58 pm   #2  (permalink
Sunbird22358
Oday Day Sailer
Wareham, MA
Sunbird22358's Avatar
Sunbird22358 hasn't generated any comments yet, may be new around here
Re: Hardware help
The original mounting plate for the mainsheet block was either bolted to a metal plate imbedded in the fiberglass or more likely, the fiberglass was just drilled and tapped. The glass seems to be thick enough at that point to allow this. I've removed the plate fro mthe CB trunk on my 1979 DS II a few times for cleaning and the screws can out fine and threaded back in fine. Does the new Garhauer setup have the same hole pattern? If so, just screw it on in place of the old one (mine is a Schafer), if not you will need to fill in the old holes and redrill and tap for the new screws. I'd suggest a call to Rudy at D&R for info on doing this. (508) 644-3001
Sunbird22358 is offline
Reply
Search this Thread:
Advanced Search
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Visit our store at
OdayOwners.com...
30% off custom embroidered sportswear
Polos, jackets, sweatshirts... mens, womens, childrens... all with NO minimum, NO setup fees, super-saver prices!
15% off unbreakable engraved drinkware SALE
Bulletproof Lexan drinkware engraved with your boat name. Wine, champagne, beer, tumblers, pitchers, more.
Solar/wind charger
Charge cell phone, MP3 players, cameras, more, without AC or DC power!
15% off butcherblock stove top cutting board
Our butcher block stove top cover is a true work of art! Turn your stove top into useable counter.
Halyard retriever
Don\'t go up the mast! Also works as a handy grapling hook. Sturdy stainless construction.
